Cisco Cisco 1801 ADSL/POTS Router w/Firewall/IDS And IPSEC 3DES
Quicklinx: 7FZMWS00 Mfr#: CISCO1801/K9
Cisco Systems is redefining best-in-class enterprise and small- to midsize-business routing with a new line of integrated services routers that are optimized for the secure delivery of data services. Founded on years of leadership and innovation, the Cisco 1800 Series integrated services routers intelligently embed data, security, and wireless technology into a single, resilient system for fast, secure, scalable delivery of mission-critical business applications. The best-in-class Cisco 1800 Series architecture has been specifically designed to meet requirements of small to medium-sized businesses (SMBs), enterprise branch offices, and service provider-managed services applications for delivery of concurrent services at wire-speed performance. The integrated secure systems architecture of the Cisco 1800 Series delivers maximum business agility and investment protection.
  • Robust security
    Equipped with AES, DES, and Triple DES encryption algorithms, this router ensures secure data transmission, safeguarding against unauthorized access and threats.
  • Efficient connectivity
    Featuring an integrated 8-port switch and support for Ethernet and Fast Ethernet, the router facilitates efficient network connectivity and data link protocols for streamlined operations.
  • Advanced management
    With support for HTTP and SNMP remote management protocols, this device offers comprehensive control and monitoring capabilities, enabling efficient network management.
  • Reliable performance
    Designed to operate within a wide range of temperatures from 0°C to 40°C and compliant with multiple safety standards, this router promises reliable performance under various environmental conditions.
Cisco 1801 - router - DSL modem - desktop
Router - DSL modem - 8-port switch (integrated)
Enclosure Type
Desktop - 1U
Digital Signaling Protocol
ADSL
WAN Ports Qty
3
Ethernet, Fast Ethernet
Performance
VPN throughput (3DES IPSec): 40 Mbps , Firewall throughput: 100 Mbps
Network / Transport Protocol
IPSec
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, EIGRP
Remote Management Protocol
SNMP, HTTP
Firewall protection, VPN support, load balancing, SPI, IPS, URL filtering
IEEE 802.1Q
34.3 cm x 27.4 cm x 4.4 cm
2.8 kg
Router - 8-port switch (integrated)
Enclosure Type
Desktop - 1U
Wired
Max Range Indoors
97.5 m
Performance
IPSec
Routing Protocol
SNMP, HTTP
Encryption Algorithm
DES, Triple DES, AES
IEEE 802.1Q, EN 60950, IEC 60950, UL 60950, CSA 22.2 No. 60950
RAM
128 MB (installed) / 384 MB (max)
Flash Memory
32 MB (installed) / 128 MB (max)
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL
Protocols & Specifications
ITU G.992.1 (G.DMT)
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL , LAN: 8 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x BRI ST , Management: 1 x console , Serial: 1 x auxiliary
Expansion Slots
1 CompactFlash , Memory
Internal power supply - 50 Watt
Rack Mounting Kit
Optional
OS Provided
Cisco IOS Advanced IP services
34.3 cm
27.4 cm
4.4 cm
2.8 kg
10 - 85%
