WS-X6148A-GE-TX is Cisco Catalyst 6500 48-Port 10/100/1000 Classic Interface Module with Power over Ethernet (PoE) option-refreshed module that supports jumbo frames and enhanced QoS capabilities.
- Cisco - expansion module - Gigabit Ethernet x 48
- Expansion module
- Form Factor
- Plug-in module
- Ports
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Designed For
- Catalyst 6500, 6503, 6506, 6506-E, 6509, 6509-E, 6509-NEB, 6509-NEB-A, 6513
- Expansion module
- Form Factor
- Plug-in module
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- 48 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x Expansion Slot
- Designed For
- Cisco Catalyst 6500, 6503, 6503 Firewall Security System, 6506, 6506 chassis, 6506 Firewall Security System, 6506-E, 6506-E chassis with Supervisor Engine 32, 6509, 6509 chassis, 6509 Firewall and IDS Security System, 6509 Firewall and VPN Security System, 6509 Wiring Closet Bundle, 6509-E, 6509-E chassis with Supervisor Engine 32, 6509-NEB, 6509-NEB-A, 6513, 6513 chassis
