Cisco Catalyst 2960-X series switch is the next generation of the world's most widely deployed access switches. It enables intelligent services such as application visibility; smart operations layer 3 routing and deliver best-in-class energy efficiency with up to 80 percent energy savings.
ETHERNET PORT CONFIGURATION
24 10/100/1000 Gigabit Ethernet ports, two 10 G SFP+ uplink ports -
DEVICE MANAGEMENT
Web UI, over-the-air access via Bluetooth and CLI (command-line interface) -
CONSOLE ACCESS
SNMP (Simple Network Management Protocol) and RJ-45 or USB console access -
SECURITY
802.1X, Switched Port Analyser (SPAN) and Bridge Protocol Data Unit (BPDU) Guard -
PEACE OF MIND
Enhanced limited lifetime warranty
- Cisco Catalyst 2960X-24TD-L - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 2 x SFP+
- Performance
- Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 95.2 Mpps
- Capacity
- Active VLANs: 1023
- Jumbo Frame Support
- 9216 bytes
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, CLI
- Full duplex capability, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, MLD snooping, DAI, Cisco EnergyWise technology, URPF, UDLD, Rapid PVST+, SRR, LLDP support, DHCP relay, LACP, MAC Address Notification, RSPAN, HSRP support, Energy Efficient Ethernet, MIB, MVR, SPQ, CoS, Cisco FlexStack Plus, DSCP support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP), IEEE 802.3az, IEEE 802.1AX
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 44.5 cm x 27.9 cm x 4.5 cm
- 4 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 9216 bytes
- Max Units In A Stack
- 8
- Authentication Method
- Kerberos, Secure Shell (SSH), RADIUS, TACACS+
- Processor
- 1 APM86392: 600 MHz
- RAM
- 512 MB
- Flash Memory
- 128 MB
- Status Indicators
- Port transmission speed, port duplex mode, system, status, RPS (Redundant Power Supply), link/activity
- 24 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 1 x mini-USB Type B management , 1 x USB Type A , 1 x management (Gigabit LAN) RJ-45 , 2 x SFP+ uplink
- Expansion Slots
- 1 (total) / 1 (free) x Stacking Module
- Power Device
- Internal power supply
- Power Redundancy
- Optional
- Voltage Required
- 24.9 watt
- Redundant Power System (RPS) connector
- MTBF
- 569,520 hours
- CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class A, KN24, KN22 Class A, RoHS 2011/65/EU, EN 300386
- Software Included
- Cisco IOS LAN Base
- 44.5 cm
- 27.9 cm
- 4.5 cm
- 4 kg
- Limited warranty - replacement - lifetime - response time: next business day ¦ Technical support - consulting - 90 days
- -5 °C
- 45 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
Cisco 10GBASE-SR SFP Module | In Stock | £367.88 |
Cisco 10GBASE-CU SFP+ CABLE 5 METER | In Stock | £112.38 |
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.16 |
Cisco AC Power Cord (UK), C13, BS 1363, 2.5m | In Stock | £34.89 |
Cisco Console Cable 6 ft with USB Type A and mini-B | In Stock | £79.70 |
Cisco 10GBASE-CU SFP+ Cable 1 Meter | In Stock | £74.60 |
Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m | In Stock | £61.20 |
Cisco AC Power Cord | In Stock | £40.46 |
Cisco Connectors/Cabinet Power Cord 250 VAC | In Stock | £20.99 |
Cisco SFP+ Copper Twinax Cable 2m - Brown | In Stock | £100.87 |
Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LR LC/PC | In Stock | £1,494.79 |
