Cisco 10GBASE-CU SFP+ Cable 1 Meter
Quicklinx: 7RTNWS00 Mfr#: SFP-H10GB-CU1M=
Length: 1m
28 In Stock
£75.29 ex VAT
£90.34 inc VAT
Cisco SFP+ Copper Twinax cables are suitable for very short distances. Twinax cables offer a highly cost-effective way to connect within racks and across adjacent racks.
  • Efficient connectivity
    The Cisco SFP+ Copper Twinax Cable is designed for high-speed data transmission, featuring twinaxial cable technology that ensures a reliable connection between devices. With both left and right connectors being SFP+, it seamlessly integrates with compatible Cisco devices, including switches and network management devices.
  • Durable design
    Crafted with a 30 American Wire Gauge (AWG), this direct attach cable is built for durability and long-term use. Its robust design supports the demands of daily operations, making it an ideal choice for establishing secure and stable network connections.
Cisco SFP+ Copper Twinax Cable - direct attach cable - 1 m
Direct attach cable
Twinaxial
Length
1 m
Connector
SFP+
Connector (Second End)
SFP+
250 Series; Catalyst 2960, 2960-24, 2960-48, 2960G-24, 2960G-48, 2960S-24, 2960S-48, ESS9300; Nexus 93180, 9336, 9372; UCS 6140, C4200
Network Cable Type
Direct attach cable
Twinaxial
30
Length
1 m
Connector
SFP+
SFP+
Cisco 250 Series SG250X-48P , Cisco Catalyst 2960-24LC-S, 2960-24PC-L, 2960-24PC-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-8TC, 2960-8TC-S, 2960G-24TC, 2960G-48TC, 2960G-8TC, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, ESS9300 Embedded Series , Cisco Nexus 93180YC-FX, 9336C-FX2, 9372PX-E , Cisco UCS 6140XP Fabric Interconnect, C4200 Rack Server Chassis
Length: 1m
Brand: Cisco
