The Cisco 819 integrated services router family, designed in compact hardened and non-hardened form factors, is the small Cisco IOS software router with support for integrated fourth-generation (4G LTE) wireless WAN (mobile broadband backhaul) and WLAN capabilities. The Cisco 819 ISR gateway provides a rapidly deployable, highly available, reliable, and secure solution designed specifically for machine-to-machine (M2M) applications. Markets that benefit from these applications include industrial automation, transportation, financial, health care, utility, and retail.
Ability to host networks in motion
The Cisco 819 uses standards-based Mobile IP features in Cisco IOS software to host networks in motion. Transition to different wireless networks is transparent to the users and devices (such as laptops, smart devices, and surveillance cameras), and applications maintain continuous connectivity without the user's manual intervention as WAN links change. In addition to allowing a single node or device to stay connected, the Cisco 819 allows an entire mobile network or subnet to stay connected. -
Retail VPN
Retail stores migrating from dialup connections for point-of-sale transactions can use the 4G LTE wireless WAN option on the Cisco 819 for low-cost broadband access with the required security to comply with payment-card-industry and other data security requirements. Multiple devices and applications can then be added to the store network to take advantage of the increased bandwidth and to enable secure mobility and enhance productivity.
- Cisco 819 4G LTE M2M Gateway - router - WWAN - desktop
- Router - wireless cellular modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Mobile Communication Protocol
- GSM, GPRS, UMTS, EDGE, HSPA+, LTE, DC-HSPA+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet
- Capacity
- IPSec VPN tunnels: 20
- IPSec
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, GRE, policy-based routing (PBR), WCCP, Bidirectional Forwarding Detection (BFD)
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, SSH, CLI
- Firewall protection, NAT support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, content filtering, DiffServ support, MAC address filtering, IPv6 support, Intrusion Prevention System (IPS), firmware upgradable, Low-latency queuing (LLQ), Class-Based Weighted Fair Queuing (CBWFQ), Weighted Fair Queuing (WFQ), Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), Dynamic Multipoint VPN (DMVPN), RADIUS support, DHCP server, Virtual Route Forwarding-Lite (VRF-Lite), DNS proxy, DHCP relay, DHCP client
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x
- Power
- AC 120/230 V (50/60 Hz)
- 19.6 cm x 20.6 cm x 4.4 cm
- 1.5 kg
- Localisation
- Europe
- 1-year warranty
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Capacity
- IPSec
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, PKI, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, TACACS+
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, FCC CFR47 Part 15, UL 60950-1 Second Edition, MIL-STD 810G, BSMI CNS 13438, EN 301 908, VCCI V-3, IP41, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, SAE J 1455, EN 301 489-7, EN 301 489-1, EN 300 386, EN 301 489-24, EN 301 511
- RAM
- 1 GB (installed) / 1 GB (max)
- Flash Memory
- Status Indicators
- System, active, wireless
Communications
- Wireless cellular modem
- Max Transfer Rate
- 100 Mbps
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x RJ-45 , USB: 1 x mini-USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- Voltage Required
- Localisation
- Europe
- OS Provided
- Cisco IOS Advanced IP services
- 19.6 cm
- 20.6 cm
- 4.4 cm
- 1.5 kg
- Limited warranty - 1 year
- -25 °C
- 60 °C
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.56 |
