The Cisco 880G Series 4G LTE 2.0 ISRs are fixed-configuration routers that provide collaborative business solutions for secure voice and data communications to enterprise small branch offices. They provide persistent, reliable LTE connectivity with fallback and transparent handoff to earlier technologies. The routers are designed to deliver secure broadband, Metro Ethernet or any xDSL variants, wireless WAN (WWAN) connectivity, and business continuity.
Robust connectivity
Equipped with both Ethernet and Fast Ethernet capabilities, the Cisco 887VAG 4G LTE 2.0 ISR ensures reliable, high-speed wired connections for a variety of network needs. -
Versatile mobile broadband
Supporting a wide range of cellular protocols including LTE, HSPA+, and GSM, this router offers extensive coverage and flexibility for mobile broadband connectivity. -
Comprehensive security
With AES, DES, and Triple DES encryption algorithms, the device provides robust security measures to protect sensitive data transmitted over the network. -
Flexible management options
Featuring support for CLI, HTTP, SNMP, and Telnet, the router allows for versatile remote management, enabling efficient network administration and monitoring.
- Cisco 887VAG 4G LTE 2.0 ISR - router - DSL/WWAN - desktop
- Router - DSL modem / wireless cellular modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2, ADSL2+, VDSL2
- Mobile Communication Protocol
- GSM, GPRS, UMTS, EDGE, HSPA+, LTE
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet
- Remote Management Protocol
- SNMP, Telnet, HTTP, CLI
- 32.5 cm x 26.4 cm x 4.8 cm
- 2.54 kg
- Localisation
- Australia, Europe
- 1-year warranty
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Encryption Algorithm
- DES, Triple DES, AES
- CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, UL 60950-1 Second Edition, BSMI CNS 13438, VCCI V-3, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, AS/NZS CISPR 22, EN 301 489-7, EN 301 489-1, EN 300 386, EN 301 489-24, EN 301 511
- RAM
- 1 GB (installed) / 1 GB (max)
- Flash Memory
- Built-in Devices
- GPS
Communications
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ , Management: 1 x console - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , Management: 1 x mini-USB Type B , Antenna: 1 x SMA
- Expansion Slots
- 2 (total) / 2 (free) x SIM
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Localisation
- Australia, Europe
- 32.5 cm
- 26.4 cm
- 4.8 cm
- 2.54 kg
- Limited warranty - 1 year
