Cisco 887VA Annex A router with VDSL2/ADSL
Quicklinx: 9R7SWS00 Mfr#: C887VA-W-E-K9
The Cisco 880 ISR provides Internet, VPN, data, and backup capability to corporate teleworkers and remote and small offices of fewer than 20 users. These routers are capable of bridging and multiprotocol routing between LAN and WAN ports, and provide advanced features such as antivirus protection.
  • Robust security
    Equipped with advanced encryption algorithms including 128-bit AES, 192-bit AES, 256-bit AES, and Triple DES, this router ensures secure data transmission and protects against unauthorized access, making it ideal for sensitive communication.
  • Comprehensive connectivity
    Featuring a 4-port switch, VDSL2/ADSL2+ over POTS, and support for multiple VPN protocols, this router offers versatile connectivity options for various networking needs, ensuring reliable and fast Internet access.
  • Enhanced performance
    With support for IPv6, Quality of Service (QoS), and MIMO technology, the router delivers high-speed, efficient, and stable network performance, catering to the demands of modern businesses and intensive online activities.
  • Easy management
    Remote management protocols including SNMP 3, HTTP, and HTTPS, along with CLI for advanced configuration, make it straightforward to monitor and manage the network, ensuring optimal performance and security.
Cisco 887VA Annex A router with VDSL2/ADSL2+ over POTS 802.11n ETSI Compliant - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, VDSL2
WAN Ports Qty
2
Ethernet, Fast Ethernet
IPSec VPN tunnels: 20
Network / Transport Protocol
L2TP, IPSec, PPPoE, PPPoA, DHCP, DNS
Routing Protocol
RIP-1, RIP-2, HSRP, VRRP, GRE, policy-based routing (PBR)
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
Firewall protection, DHCP support, NAT support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, SPI, DiffServ support, MAC address filtering, Broadcast Storm Control, IPv6 support, IPS, LLQ, CBWFQ, WFQ, MIMO technology, STP support, ACL support, QoS, DHCP server, DNS proxy
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x
32.5 cm x 26.4 cm x 4.4 cm
2.5 kg
1-year warranty
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Routing Protocol
Encryption Algorithm
LEAP, DES, Triple DES, MD5, SSL, TLS, PEAP, TTLS, TKIP, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, Radio Service Set ID (SSID), TACACS+, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, ETSI, VCCI-II, EN55024, CSA 22.2 No. 60950, EN55022 Class B, AS/NZ 3548 Class B, AS/NZS 60950-1, CS-03, EN 60555-2, UL 60950-1, IEC 60950-1
RAM
256 MB (installed) / 768 MB (max) - DDR2 SDRAM - SO-DIMM 200-pin
Flash Memory
128 MB
Status Indicators
Port status, power
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.994.1 (G.hs), ITU G.992.3 Annex A, ITU G.993.2, ITU G.992.5 Annex A
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x ADSL2+ , USB: 1 x 4 pin USB Type A , WAN: 1 x VDSL2
Expansion Slots
1 (total) / 1 (free) x SO-DIMM 200-pin
External power adapter - 60 Watt
OS Provided
Cisco IOS Advanced Security
32.5 cm
26.4 cm
4.4 cm
2.5 kg
Limited warranty - 1 year
10 - 85% (non-condensing)
9R7S C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
