Cisco 870 Series of integrated services routers are fixed-configuration routers that support multiple types of DSL technologies, broadband cable, and Metro Ethernet connections in small offices. They provide the performance needed to run concurrent services, including firewall, intrusion prevention, and encryption for VPNs; optional 802.11b/g for WLAN networking; and quality of service (QoS) features for optimizing voice and video applications. In addition, the Cisco Router and Security Device Manager (SDM) Web-based configuration tool simplifies setup and deployment, and centralized management capabilities give network managers visibility and control of the network configurations at the remote site.
- Cisco 877W - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 54 Mbps
- Capacity
- VPN tunnels: 10
- PPTP, L2TP, IPSec, PPPoE, PPPoA
- Routing Protocol
- RIP-1, RIP-2
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, HTTPS
- Firewall protection, auto-sensing per device, DHCP support, NAT support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), SPI, manageable, MAC address filtering, IPv6 support, IPS, WMM support, ACL support, QoS, NAC
- IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Power
- AC 120/230 V (50/60 Hz)
- 26 cm x 23.2 cm x 5.1 cm
- 1 kg
- Localisation
- Europe
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 54 Mbps
- Capacity
- VPN tunnels: 10
- Routing Protocol
- RIP-1, RIP-2
- Encryption Algorithm
- LEAP, Triple DES, MD5, AES, TLS, PEAP, TKIP, WPA, WPA2
- Authentication Method
- RADIUS, Radio Service Set ID (SSID), TACACS+
- IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, ETSI, EN 60950, IEC 61000-3-2, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, IEC950, VCCI-II, EN55022 Class B, ICES-003 Class B, AS/NZ 3548 Class B, AS/NZS 3260, FCC Part 68, CS-03, UL 1950 Third Edition, EN 60555-2
- RAM
- 128 MB (installed) / 256 MB (max)
- Flash Memory
- 24 MB (installed) / 52 MB (max)
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.3 (G.DMT.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.1 (G.DMT) Annex B, ITU G.992.5 Annex A
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL - RJ-11 , Management: 1 x console - RJ-45
Aerial
- Aerial
- External detachable
- Gain Level
- 2.2 dBi
- Power Device
- External power adapter - 26 Watt
- Voltage Required
- Localisation
- Europe
- 26 cm
- 23.2 cm
- 5.1 cm
- 1 kg
- 0 °C
- 40 °C
- 10 - 85%
