Cisco 5.2dbi Omni Antenna
Quicklinx: 2LMYWS00 Mfr#: AIR-ANT1728
Every wireless Local Area Network (LAN) deployment is different. When engineering an in-building solution, varying facility sizes, construction materials, and interior divisions raise a host of transmission and multipath considerations. When implementing a building-to-building solution, distance, physical obstructions between facilities, and number of transmission points must be taken into account.
Cisco is committed to providing not only the best access points, client adapters, and bridges in the industry-it is also committed to providing a complete solution for any wireless LAN deployment. That's why Cisco has the widest range of antennas, cable, and accessories available from any wireless manufacturer.
Cisco offers an Antenna Kit with 5.2 dbi Omni Ceiling Mount Antenna and 3-feet cable.
  • Effortless installation
    The Cisco Aironet High Gain Omnidirectional Ceiling Mount Antenna is designed for easy ceiling-mountable setup, ensuring a hassle-free installation process for enhancing wireless network coverage.
  • Enhanced connectivity
    With a gain of 5.2 dBi, this antenna extends the reach of wireless networks, providing improved signal strength and reliability for connected devices across different environments.
  • Versatile compatibility
    Engineered to be compatible with PC systems, this antenna seamlessly integrates with existing network infrastructures, offering a straightforward solution for expanding wireless access point capabilities.
Cisco Aironet High Gain Omnidirectional Ceiling Mount Antenna - antenna
Antenna
3.2 cm 22.8 cm
131 g
Aerial Placing / Mounting
Ceiling mountable
Gain
5.2 dBi
Directivity
Omni-directional
Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
Antenna
3.2 cm
22.8 cm
131 g
Aerial
Ceiling mountable
Gain
5.2 dBi
Directivity
Omni-directional
Cabling & Wiring
Connector Provided
1 x RP-TNC
Cisco Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
