Cisco 3504 Wireless Controller
Quicklinx: DZHKWS00 Mfr#: AIR-CT3504-K9
  • IEEE 802.11n
£1,952.20 ex VAT
£2,342.64 inc VAT
The Cisco 3504 Wireless Controller provides centralized control, management, and troubleshooting for small to medium-sized enterprises and branch offices. It offers flexibility to support multiple deployment modes in the same controller - a centralized mode for campus environments, Cisco FlexConnect mode for lean branches managed over the WAN, and a mesh (bridge) mode for deployments in which full Ethernet cabling is unavailable. As a component of the Cisco Unified Wireless Network, the 3504 controller provides real-time communications between Cisco Aironet Access Points, Cisco Prime Infrastructure, and the Cisco Mobility Services Engine, and is interoperable with the Cisco 5520 and 8540 Wireless Controllers.
Cisco Wireless Controller 3504 - network management device
Network management device
Desktop
Ports Qty
4
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, 10 Gigabit Ethernet, IEEE 802.11n, IEEE 802.11ac Wave 2, IEEE 802.11ac Wave 1
Performance
Throughput: 4 Gbps
Maximum number of access points: 150 , Maximum number of clients: 3000 , VLANs supported: 4096
Power Over Ethernet (PoE) Supported
PoE
4.394 cm x 34.13 cm x 21.59 cm
2 kg
90 days warranty
4.394 cm
34.13 cm
21.59 cm
2 kg
Desktop
Ports Qty
4
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, ARP, BOOTP, DHCP
Routing Protocol
CIDR
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH
Performance
Throughput: 4 Gbps
Status Indicators
Diagnostic
Syslog support, IPv6 support, deep inspection, SNTP support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, CleanAir technology, Unified Communications, CAPWAP support, Management Information Base (MIB), Multicast filtering function, Cisco VideoStream technology, Link Aggregation, Management Information Base (MIB) II, Application Visibility and Control (AVC), TrustSec support, Private MIB
Encryption Algorithm
DES, Triple DES, RC4, AES, IKE, TLS 1.0, TKIP, WPA, WPA2, PKI, AES-CBC, DTLS, WEP, TLS 1.2, ESP, ISAKMP, CRL, CBS, CCM, CCMP
Authentication Method
RADIUS, TACACS, Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.1ae, IEEE 802.11n, IEEE 802.11k, IEEE 802.1AX, IEEE 802.11w, IEEE 802.11r, IEEE 802.11u, IEEE 802.11ac Wave 2
1 x 10GBase-T - RJ-45 , 4 x 1000Base-T - RJ-45 , 1 x console - RJ-45 , 1 x serial - RJ-45 , 1 x redundancy - RJ-45 , 1 x console - mini-USB , 1 x USB 3.0
EN 61000-3-2, EN55024, AS/NZS 60950-1, ICES-003 Class A, UL 60950-1 Second Edition, FCC CFR47 Part 15 B, HMAC, Directive 2004/108/EC, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, Directive 2006/95/EC, VCCI Class B, KN24, KCC KN22 Class B, CAN/CSA C22.2 No. 60950-1 Second Edition, EN 6100-3-3, EN 55032 Class B, CNS 13438 Class B
PoE
Limited warranty - replacement - 90 days - response time: 10 days
5 - 95% (non-condensing)
Brand: Cisco
Price Range Ex VAT: 1500+
