Cisco 2911 Router Gigabit LAN rack-mountable
Quicklinx: 91YBWS00 Mfr#: CISCO2911/K9
The Cisco 2900 series offer unparalleled total cost of ownership savings and network agility through the intelligent integration of market leading security, unified communications, wireless, and application services.
The Cisco 2900 series ISRs offer embedded hardware encryption acceleration, voice- and video-capable digital signal processor (DSP) slots, optional firewall, intrusion prevention, call processing, voicemail, and application services. In addition, the platforms support the industries widest range of wired and wireless connectivity options such as T1/E1, xDSL, copper and fiber GE.
  • Services integration
    The Cisco 2900 series ISRs offer increased levels of services integration with voice, video, security, wireless, mobility, and data services, enabling greater efficiencies and cost savings.
  • Services on demand
    The Cisco Services Ready Engine (SRE) enables a new operational model which allows you to reduce capital expenditures (CapEx) and deploy a variety of application services as needed on a single integrated compute services module.
  • High performance with integrated services
    The Cisco 2900 series enables deployment in high speed WAN environments with concurrent services enabled up to 75 Mbps. A multigigabit fabric (MGF) enables high-bandwidth module-to-module communication without compromising routing performance.
  • Network agility
    Designed to address customer business requirements, the Cisco 2900 series modular architecture offers increased capacity and performance as your network needs grow. Modular interfaces offer increased bandwidth, a diversity of connection options, and network resiliency.
Cisco 2911 - router - rack-mountable
Router
Enclosure Type
Rack-mountable - modular - 2U
WAN Ports Qty
3
Network / Transport Protocol
IPSec, L2TPv3
Routing Protocol
OSPF, IS-IS, BGP, EIGRP, DVMRP, PIM-SM, static IP routing, IGMPv3, GRE, PIM-SSM, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), MPLS, Bidirectional Forwarding Detection (BFD), IPv4-to-IPv6 Multicast
Remote Management Protocol
SNMP, RMON, TR-069
Firewall protection, VPN support, MPLS support, Syslog support, IPv6 support, CBWFQ, WRED, WSMA, NetFlow
IEEE 802.3, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824
43.8 cm x 30.5 cm x 8.9 cm
8.2 kg
90 days warranty
Router
Enclosure Type
Wired
IPSec, L2TPv3
Routing Protocol
SNMP, RMON, TR-069
IEEE 802.3, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824, CISPR 22 Class A, CISPR 24, EN55024, EN55022 Class A, EN50082-1, AS/NZS 60950-1, ICES-003 Class A, CS-03, R&TTE, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, AS/NZS 3548 Class A, VCCI V-3, EN 61000, TIA/EIA/IS-968, EN 300 386, CAN/CSA-C22.2 No. 60950-1
RAM
512 MB (installed) / 2 GB (max)
Flash Memory
256 MB (installed) / 8 GB (max)
Status Indicators
Power, link/activity
3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , Management: 1 x console - mini-USB Type B , Serial: 1 x auxiliary - RJ-45 , USB: 2 x 4 pin USB Type A
Expansion Slots
4 (total) / 4 (free) x EHWIC , 2 (total) / 1 (free) x CompactFlash , 1 (total) / 1 (free) x expansion slot , 1 (total) / 1 (free) x service module (SM) , 2 (total) / 2 (free) x PVDM
Internal power supply
OS Provided
Cisco IOS IP Base
43.8 cm
30.5 cm
8.9 cm
8.2 kg
Limited warranty - 90 days
5 - 85%
91YB C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
