Cisco 24-port 10/100 Switch with Gigabit Uplinks
Quicklinx: 8DQFWS00 Mfr#: SF102-24-UK
Cisco 100 series switch delivers powerful network performance and flexibility for small business networks, without the complexity. With no installation software and nothing to configure, you get an affordable, reliable network that just works, right out of the box.
  • High-performance capabilities
    With powerful network performance at an affordable price, you can give your network a boost of speed and capacity to support bandwidth-intensive applications.
  • Support for advanced technologies
    Built-in quality of service (QoS) intelligence helps maintain consistent network performance and keeps your applications running smoothly.
  • An eco-friendly solution
    Optimizes power usage to be energy efficient without compromising performance.
  • Affordability
    Designed specifically for small businesses that need a basic network with automated features that get you up running in minutes.
  • Ease of use
    Works right out of the box, there's no software to install and nothing to configure.
Cisco Small Business SF 102-24 - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x combo Gigabit SFP
Performance
Switching capacity: 8.8 Gbps , Forwarding performance (64-byte packet size): 6.5 Mpps
Flow control, Layer 2 switching, auto-negotiation, auto-uplink (auto MDI/MDI-X), Weighted Round Robin (WRR) queuing, Quality of Service (QoS), fanless
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
AC 120/230 V (50 - 60 Hz)
44.1 cm x 20.3 cm x 4.4 cm
2 kg
Linux, Apple MacOS X, Microsoft Windows
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
Performance
Status Indicators
System, link/activity
24 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
CSA, UL, UL 60950, CSA C22.2, FCC CFR47 Part 15, FCC Part 15 A
United Kingdom
44.1 cm
20.3 cm
4.4 cm
2 kg
Limited warranty - replacement - lifetime , Limited warranty - power supply and fans - 1 year , Technical support - phone consulting - 1 year , New releases update - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
8DQF C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
