Cisco 1800 Series integrated services routers are the next evolution of the award-winning Cisco 1700 Series modular access routers. The Cisco 1841 router is designed for secure data connectivity and provides significant additional value compared to prior generations of Cisco 1700 Series routers by offering more than a fivefold performance increase, integrated hardware-based encryption enabled by an optional Cisco IOS Software security image, and a dramatic increase in interface card slot performance and density while maintaining support for more than 30 existing WAN interface cards (WICs) and multiflex trunk cards (voice/WICs [VWICs]-for data only on the Cisco 1841 router) of the Cisco 1700 Series.
The Cisco 1841 router features secure, fast, and high-quality delivery of multiple, concurrent services for small-to-medium-sized businesses and small enterprise branch offices. The Cisco 1841 router offers embedded hardware-based encryption enabled by an optional Cisco IOS Software security image; further enhancement of VPN performance with an optional VPN acceleration module; an intrusion prevention system (IPS) and firewall functions; interfaces for a wide range of connectivity requirements, including support for optional integrated switch ports; plus sufficient performance and slot density for future network expansion and advanced applications as well as an integrated real-time clock.
- Cisco 1841 - router - desktop
- Router
- Enclosure Type
- Desktop - modular - 1U
- Data Link Protocol
- Ethernet, Fast Ethernet
- IPSec
- Remote Management Protocol
- SNMP, HTTP, SSH-2
- Firewall protection, hardware compression, VPN support, VLAN support, IDS, IPS, wall mountable, DMVPN, NAC
- Power
- AC 120/230 V (50/60 Hz)
- 34.3 cm x 27.4 cm x 4.4 cm
- 2.7 kg
- Router
- Enclosure Type
- Connectivity Technology
- Wired
- IPSec
- SNMP, HTTP, SSH-2
- Encryption Algorithm
- DES, Triple DES, SSL, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- Secure Shell v.2 (SSH2)
- CSA, CTR 21, CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, EN 61000-3-3, EN55024, EN55022 Class A, EN50082-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, CS-03, EN 61000-4-5, UL 60950-1
- RAM
- 128 MB (installed) / 384 MB (max) - SDRAM
- Flash Memory
- 32 MB (installed) / 128 MB (max)
- 2 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 4 pin USB Type A , Management: 1 x console , Management: 1 x auxiliary
- Expansion Slots
- 1 (total) / 0 (free) x CompactFlash , Memory , 1 (total) / 1 (free) x AIM , 2 (total) / 2 (free) x HWIC
- Installed Modules Qty (Max)
- 0 (installed) / 3 (max)
- Power Device
- Internal power supply - 50 Watt
- Voltage Required
- Rack Mounting Kit
- Optional
- OS Provided
- Cisco IOS IP Base
- 34.3 cm
- 27.4 cm
- 4.4 cm
- 2.7 kg
- 0 °C
- 40 °C
- 10 - 85%
