Brand
Cisco 10GBASE-SR SFP Module
Quicklinx: 5H9VWS00 Mfr#: SFP-10G-SR=
Type: Modules
More than 50 In Stock
£463.48 ex VAT
£556.17 inc VAT
The Cisco 10GBASE SFP+ modules offer customers a wide variety of 10 Gigabit Ethernet connectivity options for data center, enterprise wiring closet, and service provider transport applications.
Cisco - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC/PC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10 GigE
Max Transfer Distance
300 m
1.3 cm x 5.7 cm x 0.9 cm
75 g
90 days warranty
Catalyst ESS9300 Embedded Series, Switch Module 3012 for IBM BladeCenter, Switch Module 3110G for IBM BladeCenter, Switch Module 3110X for IBM BladeCenter; Nexus 5010
Plug-in module
Wired
Cabling Type
10GBase-SR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
IEEE 802.3ae
1 x Ethernet 10GBase-SR - LC/PC multi-mode x 2
Compatible Slots
1 x SFP+
1.3 cm
5.7 cm
0.9 cm
75 g
Limited warranty - 90 days
70 °C
Cisco Catalyst ESS9300 Embedded Series, Switch Module 3012 for IBM BladeCenter, Switch Module 3110G for IBM BladeCenter, Switch Module 3110X for IBM BladeCenter , Cisco Nexus 5010
5H9V Cisco 10GBASE-CU SFP+ CABLE 5 METER In Stock £118.51
5H9V Cisco 10GBASE-CU SFP+ Cable 1 Meter In Stock £80.24
5H9V Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m In Stock £79.76
5H9V Cisco SFP+ Copper Twinax Cable 2m - Brown In Stock £107.44
Type: Modules
Brand: Cisco
