Cisco 10GBASE-LR X2 Module
Quicklinx: 5KV0WS00 Mfr#: X2-10GB-LR=
The Cisco 10GBASE X2 module offers customers a wide variety of 10 Gigabit Ethernet connectivity options for data center, enterprise wiring closet, and service provider transport applications.
The Cisco 10GBASE-LR module supports a link length of 10 kilometers on standard single-mode fiber (SMF, G.652).
Cisco - X2 transceiver module - 10GbE
X2 transceiver module - SC/PC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10GbE
Max Transfer Distance
10 km
3.6 cm x 9.1 cm x 1.3 cm
300 g
90 days warranty
Cisco 8-Port 10; Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD, 4500, 4948 10; ME 4924-10GE; Supervisor Engine II-Plus-10GE
Plug-in module
Wired
Cabling Type
10GBase-LR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
IEEE 802.3ae
1 x Ethernet 10GBase-LR - SC/PC single-mode x 2
Compatible Slots
1 x X2
Laser Class 1, IEC 60825-1
3.6 cm
9.1 cm
1.3 cm
300 g
Limited warranty - 90 days
70 °C
Cisco 8-Port 10 Gigabit Ethernet Module with DFC3C, 8-Port 10 Gigabit Ethernet Module with DFC3CXL , Cisco Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD, 4500 Series Supervisor Engine V-10GE, 4948 10 Gigabit Ethernet Switch , Cisco ME 4924-10GE , Cisco Supervisor Engine II-Plus-10GE
