The Cisco 10GBASE X2 modules offer customers a wide variety of 10 Gigabit Ethernet connectivity options for data center, enterprise wiring closet, and service provider transport applications.
- Cisco X2 - X2 transceiver module - 10GbE
- X2 transceiver module - 4 x InfiniBand (SFF-8470)
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-CX4
- Data Transfer Rate
- 10 Gbps
- Data Link Protocol
- 10GbE
- 3.6 cm x 9.1 cm x 1.3 cm
- 90 days warranty
- Designed For
- Cisco 8-Port 10; Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD, 4500, 4948 10; ME 4924-10GE; Supervisor Engine II-Plus-10GE
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-CX4
- 10GbE
- 10 Gbps
- IEEE 802.3ak
- 1 x network - Ethernet 10GBase-CX4 - 4 x InfiniBand (SFF-8470)
- Compatible Slots
- 1 x X2
- 3.6 cm
- 9.1 cm
- 1.3 cm
- Limited warranty - 90 days
- 0 °C
- 40 °C
- Designed For
- Cisco 8-Port 10 Gigabit Ethernet Module with DFC3C, 8-Port 10 Gigabit Ethernet Module with DFC3CXL , Cisco Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD, 4500 Series Supervisor Engine V-10GE, 4948 10 Gigabit Ethernet Switch , Cisco ME 4924-10GE , Cisco Supervisor Engine II-Plus-10GE
