Cisco 1000Base-T GBIC
Quicklinx: 2940WS00 Mfr#: WS-G5483
The Cisco 1000BaseT Gigabit Interface Converter (GBIC) is an ideal solution for Catalyst 6500, 4000, 3550, 2950, 3500 XL and 2900 XL Series customers, providing full duplex Gigabit Ethernet connectivity to high-end workstations and between wiring closets over existing copper network infrastructures. This GBIC technology leverages the industry's flexible, standards-based 1000BaseX design, allowing for a simple and low-cost migration path to Gigabit Ethernet. Adding the new 1000BaseT GBIC to the company's range of media transceivers enhances the flexibility of deployment and application for Cisco's comprehensive line of modular and desktop platforms.
Cisco Gigabit Interface Converter - GBIC transceiver module - 1GbE
GBIC transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
1GbE
3.9 cm x 11 cm x 1.8 cm
50 g
Catalyst 2912, 2924, 2948, 2950G-12, 2950G-24, 2950G-48, 2980, 3508, 3512, 3524, 3548, 3550-12, 3550-24, 3550-48, 4500, 4912; Supervisor Engine 1A 2GE, 2-MSFC2, 2-PFC2, II, II-Plus, IV, V, V-10
Plug-in module
Wired
Cabling Type
1000Base-T
1GbE
Data Transfer Rate
1 Gbps
Status Indicators
Collision status, link/activity
Full duplex capability, hot swap module replacement
IEEE 802.3z, IEEE 802.3ab
1 x Ethernet 1000Base-T - RJ-45
Compatible Slots
1 x GBIC
FCC Class A certified
3.9 cm
11 cm
1.8 cm
50 g
Limited warranty - lifetime
45 °C
10 - 85%
Cisco Catalyst 2912MF, 2912MF-XL, 2912MF-XL Enterprise Edition, 2924M, 2924M-XL, 2924M-XL DC, 2924M-XL Enterprise Edition, 2948G, 2948G-GE-TX Gigabit Ethernet Switch, 2948G-L3, 2950G-12, 2950G-24, 2950G-24-EI, 2950G-48, 2950G-48-EI, 2980G, 2980G-A, 3508G XL Enterprise Edition, 3512 XL Enterprise Edition, 3512G XL Enterprise Edition, 3512XL Standard Edition, 3524-PWR XL Enterprise Edition, 3524XL Enterprise Edition, 3548XL Enterprise Edition, 3550-12G, 3550-12T, 3550-24 EMI, 3550-24 PWR EMI, 3550-24 PWR SMI, 3550-24 SMI, 3550-48 EMI, 3550-48 SMI, 4500 Series Supervisor Engine V-10GE, 4912G , Cisco Supervisor Engine 1A 2GE, 1A 2GE Plus, 1A 2GE Plus MSFC & PFC, 1A 2GE Plus PFC, 2-MSFC2, 2-PFC2, II, II-Plus, IV, V, V-10GE
