Canon I-SENSYS MF635Cx Colour Laser18ppm Multifunction Printer
Quicklinx: DTHWWS00 Mfr#: 1475C027
Marketing description is not available.
  • Share space-saving, 4-in-1 functionality
    Save space and cut costs with this network-ready all-in-one, offering busy workgroups high performance mono printing, faxing, copying and color scanning in a compact unit.
  • Save time and accelerate productivity
    Print and copy straight away from sleep mode thanks to Quick First-Print technologies. Meet your most urgent deadlines with rapid output and a responsive first copy out time. A duplex automatic document feeder saves more time, delivering productive, automatic double-sided copying, scanning and faxing of two-sided originals.
  • Enhance communications, improve your workflow
    Scan documents directly to email or a network folder using powerful SEND functionality. It's the easiest way to enhance communications and speed up your workflow. Canon's compact PDF files are perfect for emailing and sharing thanks to the processing technology which ensures a small file size without compromising image quality.
  • Easy to manage and secure
    The printer support ensures seamless integration into existing corporate IT workflows and systems. The remote user interface allows users and administrators to remotely monitor and manage machine status effortlessly, directly over the network. Department ID management safeguards important settings, prevents unauthorized access to the machine's functionality and enables strict control of print, copy and fax costs.
Canon i-SENSYS MF635Cx - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Display
5"
Original Size
128 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards
Standard Media Capacity
150 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to PC, scan to USB host, iFAX
AC 230 V (50/60Hz)
45.1 cm x 46 cm x 40 cm
22 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
30000 pages
250 - 2500 pages
Display Diagonal Size
5"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, text / photo / map
Automatic Duplexing
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF, TIFF, UFRII, JPEG
Automatic Duplexing
First Print Out Time B/W
10.9 sec
First Print Out Time Colour
12 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 512 pages
PC Faxing
Yes (send only)
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
281 station(s)
Telephone / Fax Switch
Broadcast Transmission
310 stations
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, remote reception, Dual Access, Double Sided Faxing, fax memory backup, fax activity reports
Document & Media Handling
Min Original Size
128 x 139.7 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
52 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
150 sheets
1 sheet
100 sheets
Paper cassette - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 200 g/m² , ADF - 50 sheets size: 128 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 18 ppm (A4) , Printing: up to 32 ppm (A5) , Copying: up to 18 ppm (A4) , Scanning: up to 27 ipm - B/W , Scanning: up to 14 ipm - colour , Scanning: up to 47 ipm - B/W duplex , Scanning: up to 27 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering
Operating System Support
Linux, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5 or later, Windows 10, MS Windows Server 2016
Software Included
Drivers & Utilities, Presto! PageManager, iW Management Console
AC 230 V (50/60Hz)
850 Watt
Power Consumption Standby
13.6 Watt
Power Consumption Sleep
0.94 Watt
Warm-Up Time
13 sec
First Copy Out Time B/W
12 sec
First Copy Out Time Colour
14 sec
Consumables Included
1 x toner cartridge (black) - up to 1400 pages - Canon 045 Starter , 1 x toner cartridge (cyan) - up to 690 pages - Canon 045 Starter , 1 x toner cartridge (magenta) - up to 690 pages - Canon 045 Starter , 1 x toner cartridge (yellow) - up to 690 pages - Canon 045 Starter
ENERGY STAR Certified
45.1 cm
46 cm
40 cm
22 kg
Sound Emission
49 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
