Canon i-SENSYS MF3010 Mono Laser Multifunction Printer
Quicklinx: 7P7GWS00 Mfr#: 5252B012
Type: Printer / copier / scanner
Functionality: Printer/Copier/Scanner
Output Type: Monochrome
Wireless Capability: [N/A]
Technology: Laser
Hurry, only 1 left in stock!
£139.77 ex VAT
£167.72 inc VAT
Stylish, desktop solution for personal use
Make quick prints, copies and scans at your convenience, straight from your desktop with this compact mono laser printer. Ideal for home and small offices it's easy to use and energy efficient.
Desktop Mono laser 3-in-1: print, copy & scan
Modern, eye-catching design
Easy to use vertical display
18 ppm, 7.8 seconds First Print Out Time
Energy efficient
Ultra-compact, modern design
The sleek and stylish, all black design of the MF3010 makes it a very smart multifunctional laser 3-in-1. There's a high-quality mono printer, scanner and copier in one space-saving unit. Fast and economic to run, this eye-catching compact device fits easily on the desktop. It is perfect for personal or small and home office users who want more than just a printer and are looking to save time and money.
Easy to use
You can operate the MF3010 from the comfort of your chair, thanks to the simple, vertical display. This gives you convenient access to all the features you need without having to stand over the machine, saving you time and effort.
Quality and speed
Be sure of highly professional laser prints with up to 1200 x 600 dpi enhanced print resolution. This shows greater detail and produces sharp text and fine graphics. There's little waiting time for documents, with a mono printing output speed of 18 ppm. Canon's Quick First-Print technologies also means a fast First Print Out Time of 7.8 seconds.
Versatile colour scanning and copying
Increase your efficiency with the high quality colour scanner. It makes it easy to scan and copy your documents - instantly improving your productivity. There's no hanging around with a First Copy Out Time of less than 12 seconds. You can also scan direct to email, or searchable PDF using the MF Toolbox, for quick retrieval of your documents and photos.
Save energy and cut costs
Truly economical, the MF3010 leads the way in energy efficiency, without compromising on performance - allowing you to save money as well as reduce your carbon footprint. The multifunctional device is Energy Star compliant with a Typical Energy Consumption (TEC) of 0.6 kWh. In sleep mode it only consumes 1.4 watts of energy.
All-In-One cartridge
For maintenance-free operation and a continuous high quality output, all essential parts are housed in the same compact cartridge. This All-In-One cartridge, containing toner, drum and cleaning units, is easily and cleanly replaced in seconds. Use an Authentic Canon Laser Cartridge and your multifunctional device is as good as new.
Specifications:
TYPE:
Machine Type - Mono Laser All-in-One
Available Functions - Print, Copy and Scan
PRINTER:
Print Speed - Up to 18 ppm (A4)
Printing Method - Monochrome laser beam printing
Print Quality - Up to 1200 x 600 dpi with Automatic Image Refinement
Print Resolution - 600 x 400 dpi
First Print Out Time - 7.8 secs
Printer Languages - UFRII-LT
Print Margins - 5 mm-top, 6 mm- bottom, 5 mm-left and right
Toner Saver Mode - Yes
COPIER:
Copy Speed - Up to 18 ppm (A4)
First Copy Output Time (FCOT) - Approx. 12 seconds or less
Copy Resolution - Up to 600 x 600 dpi
Copy Modes - Text, Text/Photo, Text/Photo+, Photo
Multiple Copy - Up to 9 copies
Reduction / Enlargement - 50-200% in 10% increments
Toner Saver Mode - No
Other Features - 2 on 1, ID Card Copy
SCANNER:
Type - Colour
Scan Resolution - Optical: Up to 600 x 600 dpi - Enhanced: Up to 9600 x 9600 dpi
Colour Scanning Depth - 24 bit/24 bit (input/output)
Greyscales - 256 levels
Compatibility - TWAIN, WIA
Max. Scan Width - 216 mm
MEDIA HANDLING:
Scanner Type - Flatbed
Paper Input (Standard) - 150-sheet tray
Paper Output - 100-sheet
Media Types - Plain paper, Heavy paper, Recycled paper, Transparency, Label, Envelope, Index Card
Media Sizes - Tray: A4, B5, A5, Executive, Envelope (COM10, Monarch, DL, B5, C5), LTR, LGL, Statement, Custom sizes: Width 76 x 216 mm; Length 127 x 356 mm.
Media Weights - Tray: 60 to 163 g/m²
INTERFACE & SOFTWARE:
Interface Type - USB 2.0 Hi-speed
Operating System Compatibility - Windows 7/2000/ XP/ Vista, Mac OS X Version 10.4.9 - 10.7.x¹, Linux²
Software and Printer Management - Presto! Page Manager, MF Toolbox
GENERAL FEATURES:
Duty Cycle - Max. 8,000 pages per month
Warm-up Time - Approx. 10 seconds from power on
Memory - 64 MB
Control Panel - 1 digit LED
Dimensions with Trays (W x D x H) - 372 mm x 276 mm x 254 mm
Installation Space (W x D x H) - 572 mm x 632 mm x 608 mm
Weight - 8.2 Kg
Operating Environment - Temperature: 10 to 30ºC (50 to 86ºF), Humidity: 20 to 80% RH (no condensation)
Power Source - 220-240 V (±10%), 50/60 Hz (±2 Hz)
Power Consumption -
Maximum: Approx. 960W
Active: Approx. 450W
Sleep mode: Approx. 1.4 W
Typical Electricity Consumption (TEC): 0.6 kWh
Noise Levels:
Sound Power -
Active: 65.3dB or less,
Standby: 43.0dB or less
Sound Pressure -
Active: 50.4dB,
Standby: Inaudible
CONSUMABLES:
Cartridges - Cartridge 725 (1,600 pages¹)²
¹ Web distribution only. Driver release November 2011
² Web distribution only. Linux support printing only. Driver release January 2012
Cartridges
¹ Ships with 700 pages starter cartridge
² Based on ISO/IEC 19752
All specifications subject to change without notice
Technology: Laser
Max Print Speed: [N/A]
Brand: Canon
Stock Status: While stocks last
Stock Status: Clearance
