Cables Direct 45CM USB A M - D9 M ADAPTOR CABLE
Quicklinx: 64D1WS00 Mfr#: NLUSB-0039
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
NewLink offers an extensive range of computer accessories and components, all designed and manufactured to exacting standards. NewLink is committed to innovation and excellence at the cutting edge of its industry - that's why the company is almost always first to market with the very latest technology.
FEATURES
  • Compliant with the USB 1.1 specification;
  • 600 Kbps transfer rate;
  • Plug and Play compatibility;
  • USB host device drivers supplied;
  • USB type A Plug (Male) - D-Sub 9 Pin connector (Male).
NEWlink NLUSB-0039 - USB / serial cable - DB-9 to USB - 45 cm
USB / serial cable
Length
45 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
4 pin USB Type A - male
USB / serial cable
Length
45 cm
Connector
Plug and Play
