Brand
Cables Direct 2MTR USB 2.0 A - B CABLE BLACK
Quicklinx: 5CF3WS00 Mfr#: USB2-102K
Length: 2m
£0.74 ex VAT
£0.88 inc VAT
Express delivery Order within the next 9 hours for delivery tomorrow
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
FEATURES:
  • USB 2.0 and 1.1 compliant
  • High speed 480 Mbps data transfer speed
  • 4 downstream type A USB ports provided
  • Enables a PC to connect to high speed devices
  • Supports both OHCI and EHCI, data transfer speed up to 480 Mbps
  • Supports self power mode
  • Supports Plug and Play
  • Connect up to 127 USB devices
Compatibility
PC
Manufacturer
Cables Direct Limited
Packaged Quantity
1
Cable / Compliant Standards
USB / Hi-Speed USB
Cable / I/O Cable Type
USB cable
B End Gender
Male
Length
2
A End Gender
Male
Product Line
Cables Direct
B End Type
4 PIN USB Type B
A End Type
4 PIN USB Type A
Cable / Cable Subcategory
USB
Length: 2m
Brand: Cables Direct
Stock Status: While stocks last
Stock Status: Clearance
