C2G Wall Mount For Logitech Connect (TAA Compliant)
Quicklinx: D6VWWS00 Mfr#: 84050
The Wall Mount for the Logitech Connect offers security, stability, and convenience in a clean modern on wall install for conference rooms, huddle spaces, or other meeting spaces. The Logitech Connect wall mount is designed with 14 gauge steel that is capable of a sustained weight of 5 pounds—5 times greater than the weight of the Connect. The rubber cable grommet can channel an HDMI, USB, power cord, and lock through the mount providing strain relief to the cables and ensuring a clean installation. The mount is affixed to the wall with 3 tamper resistant screws. The Logitech Connect is clamped into the mount with a tamper resistant screw with 2 locking washers that ensure that it will not be removed from the mount. The clamp also maintains the vertical angle it is set to while still being able to rotate horizontally. Note: The Logitech Connect is not included with the mount.
  • Colour
  • Warranty
    1 year
C2G - mounting bracket
Mounting bracket
Placing / Mounting
Wall mountable
Package Content
Wall mount, 1/4-20 x 3/4" tamper resistant band clamp sub assembly screws, 3 #10 x 1-1/4" tamper resistant mounting screws, 2 x 1/4" heavy duty lock washers, band clamp sub assembly, rubber grommet, 6" touch fastener strap
Product Material
14 gauge steel
15.252 cm x 15.166 cm x 21.96 cm
968 g
1-year warranty
Mounting bracket
Placing / Mounting
Wall mountable
Product Material
14 gauge steel
Package Content
15.252 cm
15.166 cm
21.96 cm
968 g
TAA Compliant
Limited warranty: - 1 year
