Logitech TV Mount for MeetUp securely holds the MeetUp ConferenceCam either above or below a flat-panel monitor and attaches to the industry-standard VESA mounting points available on most TVs and monitors.
SECURELY MOUNT LOGITECH MEETUP TO A TV OR MONITOR
Logitech TV Mount for MeetUp securely holds the MeetUp ConferenceCam either above or below a flat-panel monitor and attaches to the industry-standard VESA mounting points available on most TVs and monitors -
ATTACH ABOVE OR BELOW MONITORS
The TV mount's unique design allows MeetUp to be mounted above or below a monitor. Attaching MeetUp below the TV tends to provide the most natural video experience, but this mount offers both options -
WORKS WITH MOST FLAT-PANEL TVS
Most TVs follow the VESA standard for locating mounting points on the back of TVs. The TV Mount for MeetUp features a swing arm design and multiple mounting holes to fit almost any flat-panel monitor -
A SIZE FOR EVERY SCREEN
Get the perfect fit for screens big and small. Choose TV Mount for displays up to 1397 mm (measured diagonally), or TV Mount XL for displays up to 2286 mm in size
- Logitech TV MOUNT XL - camera mount
- Product Type
- Camera mount
- Placing / Mounting
- On-the-monitor mountable
- 8.3 cm x 1.6 cm x 70 cm
- 825 g
- 2-year warranty
- Designed For
- P/N: 960-001102, 991-000411
- Product Type
- Camera mount
- 8.3 cm
- 1.6 cm
- 70 cm
- 825 g
- Mounting Kit
- Included
- VESA interface support
- Limited warranty - 2 years
- Designed For
