C2G TruLink® 4-Port UXGA Monitor Splitter/Extender with 3.5mm Audio
Quicklinx: 7BD4WS00 Mfr#: 89031
£56.81 ex VAT
£68.17 inc VAT
The TruLink 4-Port Monitor Splitter/Extender is a brilliant choice for distributing audio and video to classrooms, exhibits, tradeshows, demonstrations and multimedia presentations. This monitor splitter broadcasts your computer's audio and video output to four destinations. Daisy-chain more than one splitter to expand the number of monitors and speakers you can reach. With the built-in video signal enhancement, you can place monitors up to 64 meters away while maintaining your video quality.
Use the 3.5 mm audio outputs to drive either speakers or earphones. Suitable for XGA, SVGA, VGA, and MultiSync resolution monitors. From use in test bench facilities, data centers and help desks to video broadcasting, splitter/extender delivers both performance and value.
C2G TruLink 4-Port UXGA Monitor Splitter/Extender with 3.5mm Audio - monitor/audio switch - 4 ports
Monitor/audio switch - 4 ports
1.1 kg
Grey
1-year warranty
Enclosure Type
Desktop
Max Resolution
2048 x 1536
Max Video Bandwidth
400 MHz
4 x VGA output HD-15 , 4 x audio output mini-jack , 1 x VGA input HD-15 , 1 x audio input mini-jack
External power adapter
Grey
1.1 kg
Limited warranty - 1 year
Brand: C2G
Price Range Ex VAT: 50 - 100
