C2G Snap-In USB A/B Female Keystone Insert Module - White
Quicklinx: 8GYXWS00 Mfr#: 81300
The keystone snap-in modules provide a full range of solutions for voice, home networking, home office, audio/video and more. With the wide selection of snap-in modules, you can custom-configure your keystone wall plates and patch panels for greater control and more flexibility. Use this coupler for one USB Type A male cable connector and one USB Type B male cable connector; just snap it into patch panels, compatible wall plates and surface boxes.
  • Versatile connectivity
    This Snap-In USB A/B Female Keystone Insert Module from C2G offers seamless integration into any PC environment, providing a reliable connection point for USB devices. With a 4-pin USB Type-A connector, it ensures compatibility with a wide range of peripherals.
  • Easy installation
    Designed with practicality in mind, the keystone type module allows for straightforward snap-in installation, making it an ideal solution for organizing and extending USB connections in patch panels, outlets, and components.
C2G Snap-In USB A/B Female Keystone Insert Module - modular insert (coupling)
Modular insert (coupling) - USB
White
Port Qty
1 port
Enclosure Colour
White
Cabling & Wiring
Port Qty
1 port
Keystone type, 4 pin USB Type B socket at backside
Connector Provided
1 x 4 pin USB Type A female
