C2G RJ45/DB9M Modular Adapter Grey
Quicklinx: 686GWS00 Mfr#: 81548
Using modular adapters with inexpensive silver satin or flat oval twisted-pair wire has become a popular way to run client server applications. Many network planners have implemented modular adapters as the most cost-effective way to complete connections. Whether used in a wiring closet or throughout the office, color-coded modular adapters from C2G lend easy identification and differentiation to your cable plan. By color coding your connections, you cut down on troubleshooting time while taking full advantage of the benefits of this modular adapter approach.
  • Versatile connectivity
    This Modular Adapter by C2G offers a seamless connection between PC interfaces, featuring a female RJ-45 to male 9-pin D-Sub (DB-9) serial adapter. It's designed to support a variety of serial devices, ensuring reliable data transmission and connectivity for your essential peripherals.
  • Quality compliance
    Adhering to RoHS standards, the Modular Adapter is manufactured with a commitment to environmental responsibility and user safety. This compliance ensures that the adapter meets global regulatory requirements, making it a responsible choice for your connectivity needs.
C2G Modular Adapter - serial adapter - RJ-45 to DB-9
Serial adapter
Connector
RJ-45 - female
Connector (Second End)
9 pin D-Sub (DB-9) - male
Grey
Serial adapter
Grey
Connector
RJ-45 - female
RoHS
