C2G Pro DVI-D to VGA Converter - Video converter - Black
Quicklinx: 95XXWS00 Mfr#: 82401
The C2G Pro DVI-D to VGA Converter provides a reliable connection between more modern laptops, computers or other devices with a DVI-D output to legacy displays, such as projectors or monitors, which accept a VGA input. The Pro DVI-D to VGA and Audio converter is an active device which converts a digital DVI-D A/V signal to an analogue VGA Video signal and supports high quality video resolutions up to 1920 x 1200 at 60Hz. This product offers straightforward installation with no software or drivers required: simply connect the unit and enjoy high definition content on an analogue display. The durable metal housing protects the converter and ensures a long life. For added convenience, this device is bus powered from the DVI-D port, so no additional power source is required. A 3.5mm stereo audio output is also included so that audio can be enjoyed through the display.
  • Seamless compatibility
    Designed specifically for PC use, this Pro DVI-D to VGA Converter ensures a smooth and hassle-free connection between your DVI-D input devices and VGA output displays.
  • High-quality resolution
    Supports a maximum external resolution of 1920 x 1200, providing clear and detailed visuals for an enhanced viewing experience. The 60 Hz V-Sync rate at max resolution ensures smooth video playback without any lag.
  • Versatile connectivity
    Equipped with a 24+5 pin combined DVI connector for input and a 15 pin HD D-Sub (HD-15) connector for output, this converter offers flexible connection options to meet your various needs.
C2G Pro DVI-D to VGA Converter - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
1920 x 1200
1 x DVI-D input - 24+5 pin combined DVI , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Enclosure Colour
1-year warranty
Video converter
Max Resolution
1920 x 1200 at 60 Hz
Enclosure Colour
Limited warranty - 1 year
