C2G HDMI Male Flying Lead Rx Rapidrun Optical Receiver
Quicklinx: DWQGWS00 Mfr#: 84131
RapidRun Optical is designed to be the standard for in-wall HDMI audio/video installations. Using pre-terminated break-away flying leads and wall plates with an in-wall runner ensures flexible, efficient, high quality connections for all types of equipment, with no field terminations. Ideal for high resolution displays utilising HDMI, this flying lead allows for an extremely clean finish with little to no cable clutter at the source.
  • Colour
  • Warranty
    3 years
  • Connector A
    RapidRun Optical Female
  • Connector B
    (1) HDMI Male (1) USB Micro-B Female
C2G RapidRun Optical HDMI Receiver Flying Lead - digital audio adapter - 10.1 cm
Cable
Digital audio adapter
Length
10.1 cm
Connectors
RapidRun optical - female
Connectors (Second End)
HDMI - male , Micro-USB Type B (power only) - female
Audio Return Channel (ARC), HDMI CEC support (Consumer Electronics Control), Ethernet Return Channel, HDCP compliant
3-year warranty
Cable Type
Length
10.1 cm
Connectors
19 pin HDMI Type A - male , 5 pin Micro-USB Type B (power only) - female
CSA, UL, FCC, EMI, RoHS Phase 2
Limited warranty - 3 years
