This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
Seamless connectivity
Designed for optimal performance, the 3 m DisplayPort to Single Link DVI-D Adapter Cable M/M ensures a seamless connection between your DisplayPort-equipped PC and DVI-D single link display devices. This cable supports high-definition video from your computer to a monitor for video streaming or gaming; connect and configure your monitor for an extended desktop or mirrored displays -
High-quality construction
Crafted with the user in mind, this black DisplayPort to DVI adapter cable features a 20-pin DisplayPort male connector on one end and an 18+1 pin digital DVI (Single-Link) male connector on the other. The robust construction ensures durability and reliability for long-term use
- C2G 3m DisplayPort to Single Link DVI-D Adapter Cable M/M - DP to DVI - Black - DisplayPort cable - 3 m
- DisplayPort cable - single link
- Length
- 3 m
- Connector
- DisplayPort - male
- Connector (Second End)
- DVI-D - male
- Black
- Limited lifetime warranty
- DisplayPort cable
- TMDS Links
- Single link
- Length
- 3 m
- Black
- Connector
- 20 pin DisplayPort - male
- 18+1 pin digital DVI (Single-Link) - male
