This SFP (mini-GBIC) Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number GLC-BX-D. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Cisco and the Cisco logo are trademarks or registered trademarks of Cisco Systems, Inc. This product is not certified or endorsed by Cisco Systems.
- C2G - SFP (mini-GBIC) transceiver module - GigE
- SFP (mini-GBIC) transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-BX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- GigE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Cisco GLC-BX-D
- 1.27 cm x 5.59 cm x 0.76 cm
- 68 g
- Limited lifetime warranty
- Designed For
- Cisco Catalyst 2960, 2960G, 2960S, 3560, 3560E, 3560G, 3560V2, 3560X, 3750, 3750G, 3850, 4500, 4948, ESS9300; Catalyst Compact 2960; Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118; ME 2400, 3400; Nexus 93180, 9372; Supervisor Engine 720, II-Plus-10, II-Plus-TS
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-BX
- GigE
- 1 Gbps
- 1310 nm
- 10 km
- Digital Optical Monitoring (DOM) support
- 1 x Ethernet 1000Base-BX - LC single-mode female x 2
- MSA
- Cisco GLC-BX-D
- 1.27 cm
- 5.59 cm
- 0.76 cm
- 68 g
- Limited warranty - lifetime
- Designed For
- Cisco Catalyst 2960-24LC-S, 2960-24PC-L, 2960-24PC-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-8TC, 2960-8TC-S, 2960G-24TC, 2960G-48TC, 2960G-8TC, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, 3560-12PC, 3560-12PC-S, 3560-24PS EMI, 3560-24PS SMI, 3560-24TS, 3560-24TS EMI, 3560-24TS SMI, 3560-48PS, 3560-48PS EMI, 3560-48PS SMI, 3560-48TS, 3560-48TS EMI, 3560-48TS SMI, 3560-8PC, 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3560G-24PS, 3560G-24PS EMI, 3560G-24PS SMI, 3560G-24TS, 3560G-24TS EMI, 3560G-24TS SMI, 3560G-48, 3560G-48PS, 3560G-48PS EMI, 3560G-48PS SMI, 3560G-48TS, 3560G-48TS EMI, 3560G-48TS SMI, 3560V2-24PS, 3560V2-24TS, 3560V2-24TS-SD, 3560V2-48PS, 3560V2-48TS, 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S, 3750-24PS, 3750-24PS EMI, 3750-24PS SMI, 3750-24TS SMI, 3750-24TS-E, 3750-48PS, 3750-48PS EMI, 3750-48PS SMI, 3750-48TS-E, 3750-48TS-S, 3750G-12S, 3750G-12S-E, 3750G-12S-S, 3750G-24PS-E, 3750G-24PS-S, 3750G-24TS, 3750G-24T-S, 3750G-24TS EMI, 3750G-24TS-S, 3750G-48PS, 3750G-48PS-E, 3750G-48PS-S, 3750G-48TS, 3750G-48TS-E, 3750G-48TS-S, 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-24PW-S, 3850-24T-E, 3850-24T-L, 3850-24T-S, 3850-24U-S, 3850-48F-E, 3850-48F-L, 3850-48F-S, 3850-48P-E, 3850-48P-L, 3850-48P-S, 3850-48PW-S, 3850-48T-E, 3850-48T-L, 3850-48T-S, 3850-48U-S, 4500 Series Supervisor Engine V-10GE, 4948, ESS9300 Embedded Series , Cisco Catalyst Compact 2960C-8TC-L , Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118 , Cisco ME 2400-24TS, 3400-24TS , Cisco Nexus 93180YC-FX, 9372PX-E , Cisco Supervisor Engine II-Plus-10GE, II-Plus-TS
