C2G 7m LC/ST LSZH Duplex 62.5/125 Multimode Fibre Patch Cable - Orange
Quicklinx: 6C1QWS00 Mfr#: 85275
With LC to ST termination, this high quality fibre optic patch cable is specifically designed for Fast Ethernet, fibre channel, ATM and Gigabit Ethernet applications. The small LC connectors satisfy the need for higher port density both in the telecom room and the work area, and offer twice the port density of traditional SC and ST fibre connectors. The LC connector with its RJ-style latch clip design is easy to engage and disengage, and gives each connection greater durability in resisting pulls, strains, snags, and impacts during cabling installs and maintenance. The ST connector features a bayonet locking system. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs.
  • Enhanced safety
    The Low-Smoke Zero-Halogen (LSZH) jacket material ensures enhanced safety by reducing the amount of toxic and corrosive gas emitted during combustion.
  • High-quality connectivity
    Equipped with LC multi-mode and ST multi-mode connectors, this patch cable facilitates high-quality, reliable connectivity for your PC, supporting multimode fiber optic technology.
  • Robust design
    Featuring a core and cladding diameter of 62.5 / 125 micron and a dual fiber configuration, this cable is designed for durability and optimal performance in various networking environments.
C2G Low-Smoke Zero-Halogen - patch cable - 7 m - orange
Patch cable
Fibre optic
Type of Fibre Optics
Multimode
Length
7 m
Core / Cladding Diameter
62.5 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
2 x ST multi-mode - male
Orange
Network Cable Type
Patch cable
Fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
62.5 / 125 micron
Length
7 m
Orange
Connector
RoHS
