C2G 1.8m (6ft) USB C Cable M/M - USB 2.0 (3A) - Black
Quicklinx: DWQZWS00 Mfr#: 88826
Length: 1.8m
£12.06 ex VAT
£14.47 inc VAT
The USB-C to C 2.0 Male to Male Cable is the perfect solution for connecting two standard USB Type C enabled devices or accessories up to 6ft apart for fast charging and high-speed data transfer. Whether you’re desk-based or on-the-road, this one-cable solution ensures that your USB-C equipped Chromebook, laptop, smartphone or tablet is fully charged and ready to go with the 3A charging output, whilst simultaneously transferring photos, music or data at speeds up to 480 Mbps. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • Efficient charging and syncing
    This USB-C cable is designed to support both sync and charge functionality, making it a versatile accessory for your devices. With a rated current of 3 A, it ensures efficient charging and data transfer, keeping your devices powered and up to date.
  • Durable design
    Featuring nickel-plated connectors and a robust 1.8m (6ft) length, this cable is built for durability and extended use. The male-to-male USB Type-C configuration ensures compatibility with a wide range of devices, providing a reliable connection every time.
C2G 1.8m (6ft) USB C Cable - USB 2.0 (3A) - M/M USB Type C Cable - Black - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1.8 m
USB-C cable
Sync and charge
Length
1.8 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Current
3 A
USB / USB 2.0
3-year warranty
USB-C cable
Rated Current
3 A
Plated Connector
Nickel
Sync and charge
Length
1.8 m
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, RoHS 2 (2011/65/EU)
3-year warranty
Length: 1.8m
Brand: C2G
