C2G 7m LC/SC LSZH Duplex 62.5/125 Multimode Fibre Patch Cable - Orange
Quicklinx: 6C1JWS00 Mfr#: 85259
With LC to SC termination, this high quality fibre optic patch cable is specificially designed for fast ethernet, fibre channel, ATM and gigabit ethernet applications. The small LC connectors satisfy the need for higher port density both in the telecom room and the work area, and offer twice the port density of traditional SC and ST fibre connectors. The LC connector with its RJ-style latch clip design is easy to engage and disengage, and gives each connection greater durability in resisting pulls, strains, snags, and impacts during cabling installs and maintenance. The SC connector features a push-pull locking system. The LSZH jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 62.5/125 multimode fibre, immune to electrical interference.
  • Warranty Details
    This product carries a lifetime warranty
  • Jacket Rating
    The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures
  • Jacket Design
C2G Low-Smoke Zero-Halogen - patch cable - 7 m - orange
Patch cable
Fibre optic
Type of Fibre Optics
Multimode
Length
7 m
Core / Cladding Diameter
62.5 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
2 x SC multi-mode - male
Orange
Network Cable Type
Patch cable
Fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
62.5 / 125 micron
Length
7 m
Orange
Connector
RoHS
