This OM4 Duplex Multimode fibre optic cable is ideal for connecting 40GBase-SR4 and 100GBase-SR10, SFP+ and QSFP+ transceivers for 40 and 100 gigabit network connections. This cable provides backward compatibility with existing 50/125 equipment and the performance headroom required to support LED and VCSEL laser light sources, and 40 or 100 gigabit Ethernet applications in a data centre or wiring closet.
Enhanced connectivity
The 7m LC/LC OM4 LSZH Fibre Patch - Purple offers duplex connectivity with LC multi-mode male connectors on both ends, ensuring a reliable and high-quality link between your fiber optic equipment. -
High performance
With OM4 compliant standards and a core/cladding diameter of 50 / 125 micron, this patch cable is designed for high bandwidth and speed, supporting your networking needs. -
Safety first
Constructed with Low Smoke Zero Halogen (LSZH) jacket material, this cable minimizes the amount of toxic and corrosive gas emitted during combustion, making it a safer choice for your workspace.
 - C2G 7m LC/LC OM4 LSZH Fibre Patch - Purple - patch cable - 7 m - purple
 - Patch cable - OM4
- Technology
 - Duplex fibre optic
- Type of Fibre Optics
 - Multimode
- Length
 - 7 m
- Core / Cladding Diameter
 - 50 / 125 micron
- Connector
 - 2 x LC multi-mode - male
- Connector (Second End)
 - Purple
 - Limited lifetime warranty
- Network Cable Type
 - Patch cable - OM4
- Technology
 - Multimode
- Jacket Material
 - Low Smoke Zero Halogen (LSZH)
 - 50 / 125 micron
- Length
 - 7 m
 - 80 g
 - Purple
- Connector
