This Cat5e network crossover patch cable is an ideal solution for connecting two computer to share files or data. The crossed pin configuration allows two computers to be connected peer-to-peer without the need for a hub or switch. This cable may also be used to connect network switches and hubs without an uplink port to other switches and hubs. This cable is constructed to meet all Cat5e TIA/EIA standards, and has been designed to drastically reduce both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
Enhanced connectivity
The Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable is designed to connect two devices directly, such as computers, enabling a seamless network setup. With its T568B wiring scheme and a configuration that supports up to 350 MHz, this cable ensures reliable connectivity and performance for gaming, file transfers, and network applications. -
Durable design
Crafted with a PVC jacket material and featuring a gold-plated RJ-45 connector on both ends, this crossover cable is built for durability and to resist corrosion. The 24 American Wire Gauge (AWG) thickness ensures minimal signal loss, maintaining the integrity and quality of data transmission over the network.
- C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 7 m - red
- Crossover cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Stranded, uniboot
- Length
- 7 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Stranded, uniboot
- Length
- 7 m
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- Up to 350 MHz
