This OM4 Duplex Multimode fibre optic cable is ideal for connecting 40GBase-SR4 and 100GBase-SR10, SFP+ and QSFP+ transceivers for 40 and 100 gigabit network connections. This cable provides backward compatibility with existing 50/125 equipment and the performance headroom required to support LED and VCSEL laser light sources, and 40 or 100 gigabit Ethernet applications in a data centre or wiring closet.
Enhanced connectivity
The 5m LC/LC OM4 LSZH Fibre Patch - Purple offers duplex connectivity with LC multi-mode connectors on both ends, ensuring a reliable and high-quality link between your fiber optic devices. -
High-speed performance
With OM4 compliant standards and a core/cladding diameter of 50 / 125 micron, this patch cable is designed for high bandwidth and speed, supporting high data transfer rates for demanding network requirements. -
Safety first
Constructed with Low Smoke Zero Halogen (LSZH) jacket material, this cable minimizes the amount of toxic and corrosive gas emitted during combustion, making it a safer choice for your networking needs.
- C2G 5m LC/LC OM4 LSZH Fibre Patch - Purple - patch cable - 5 m - purple
- Patch cable - OM4
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 5 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Purple
- Limited lifetime warranty
- Network Cable Type
- Patch cable - OM4
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- 50 / 125 micron
- Length
- 5 m
- 60 g
- Purple
- Connector
