For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-speed connectivity
Experience seamless Internet and network connectivity with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures efficient data transfer and high-speed connections for all your computing needs. -
Durable design
Constructed with a PVC jacket material and featuring a gold-plated RJ-45 connector, this patch cable is built for durability and reliable connections. The 24 AWG American Wire Gauge specification ensures a robust and secure physical link for your network. -
Universal compatibility
With its T568B wiring scheme and compatibility with PCs, this network patch cable offers a versatile solution for connecting a wide range of devices. Whether for home or office use, it ensures a reliable connection to your network infrastructure.
 - C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - orange
 - Patch cable - CAT 6
- Technology
- Wiring Scheme
 - T568B
 - Molded, snagless, stranded
- Length
 - 5 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Orange
- Network Cable Type
- Technology
- Wiring Scheme
 - T568B
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Plated Connector
 - Gold
- Length
 - 5 m
 - Orange
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS - up to 550 MHz
