For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
Enhanced connectivity
The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 AWG American Wire Gauge copper, ensuring reliable connectivity and improved network performance. Its unshielded twisted pair (UTP) technology minimizes noise and interference, providing a stable and secure connection for all your devices. -
Durable design
Featuring a robust PVC jacket material and gold-plated connectors, this network patch cable is built for durability and long-lasting performance. The PVC jacket offers additional protection against wear and tear, while the gold-plated connectors ensure a corrosion-resistant contact for better signal clarity. -
Universal compatibility
With T568B wiring scheme and RJ-45 connectors, this patch cable offers broad compatibility with PCs and network devices. Its versatile design makes it suitable for a wide range of applications, from home networks to large data centers, ensuring seamless integration into any setup.
 - C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - grey
 - Patch cable - CAT 6
- Technology
- Wiring Scheme
 - T568B
 - Molded, snagless, stranded
- Length
 - 5 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Grey
- Network Cable Type
- Technology
- Wiring Scheme
 - T568B
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Plated Connector
 - Gold
- Length
 - 5 m
 - Grey
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS - up to 550 MHz
