C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey
Quicklinx: 6BPKWS00 Mfr#: 83370
Length: 5m
Colour: Grey
£4.30 ex VAT
£5.16 inc VAT
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • Enhanced connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 AWG American Wire Gauge copper, ensuring reliable connectivity and improved network performance. Its unshielded twisted pair (UTP) technology minimizes noise and interference, providing a stable and secure connection for all your devices.
  • Durable design
    Featuring a robust PVC jacket material and gold-plated connectors, this network patch cable is built for durability and long-lasting performance. The PVC jacket offers additional protection against wear and tear, while the gold-plated connectors ensure a corrosion-resistant contact for better signal clarity.
  • Universal compatibility
    With T568B wiring scheme and RJ-45 connectors, this patch cable offers broad compatibility with PCs and network devices. Its versatile design makes it suitable for a wide range of applications, from home networks to large data centers, ensuring seamless integration into any setup.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - grey
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
5 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 5m
Colour: Grey
Brand: C2G
