C2G 5m Cat5E 350 MHz Snagless Patch Cable - Black
Quicklinx: 6BM5WS00 Mfr#: 83185
Length: 5m
Colour: Black
15 In Stock
£4.53 ex VAT
£5.43 inc VAT
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 AWG wires, ensuring reliable connectivity and high-speed data transfer rates for optimal performance. With its tested frequency of up to 350 MHz, this cable supports a wide range of network applications, making it a versatile choice for any setup.
  • Durable design
    Featuring a robust PVC jacket material and gold-plated connectors, this network patch cable is built for durability and long-lasting use. The gold plating on the connectors provides a secure connection and prevents corrosion, ensuring that your network performance is reliable and maintains its quality over time.
  • Universal compatibility
    Designed to meet the RoHS compliant standards, this patch cable is compatible with PCs and supports a T568B wiring scheme. Its compatibility makes it an ideal choice for connecting a wide range of devices in your network, from routers to switch boxes, ensuring seamless integration into your existing setup.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - black
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
Length: 5m
Colour: Black
Brand: C2G
