For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
Enhanced connectivity
The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 AWG wires, ensuring reliable connectivity and high-speed data transfer rates for optimal performance. With its tested frequency of up to 350 MHz, this cable supports a wide range of network applications, making it a versatile choice for any setup. -
Durable design
Featuring a robust PVC jacket material and gold-plated connectors, this network patch cable is built for durability and long-lasting use. The gold plating on the connectors provides a secure connection and prevents corrosion, ensuring that your network performance is reliable and maintains its quality over time. -
Universal compatibility
Designed to meet the RoHS compliant standards, this patch cable is compatible with PCs and supports a T568B wiring scheme. Its compatibility makes it an ideal choice for connecting a wide range of devices in your network, from routers to switch boxes, ensuring seamless integration into your existing setup.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - black
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Black
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 5 m
- Black
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
