C2G 5m Cat5E 350 MHz Snagless Booted Patch Cable - Red
Quicklinx: 69NHWS00 Mfr#: 83225
Length: 5m
Colour: Red
£4.42 ex VAT
£5.30 inc VAT
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 AWG wires, ensuring reliable connectivity and high-speed data transfer rates of up to 350 MHz. Its gold-plated RJ-45 connectors provide optimal signal clarity and minimal interference, making it an ideal choice for both home and office networking needs.
  • Durable design
    Featuring a robust PVC jacket, this network patch cable is built to withstand the rigors of daily use. The boot cover for the RJ-45 connectors not only adds an extra layer of protection but also prevents the cable from snagging during installation and cable management. This design choice ensures a longer lifespan and maintains the integrity of your network.
  • Universal compatibility
    Designed to meet the RoHS compliance standards, this patch cable is compatible with a wide range of devices. Whether connecting PCs, routers, or switches, its versatile T568B wiring scheme and UTP technology make it seamlessly integrate with existing network setups without the need for additional adapters or converters.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - red
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
Length: 5m
Colour: Red
Brand: C2G
