C2G 4.6m USB A Male to Micro B Male
Quicklinx: DWQWWS00 Mfr#: 87395
Length: 4m
£4.49 ex VAT
£5.38 inc VAT
Connect to mobiles, GPS systems, PDAs, and digital cameras by using the micro-USB connection on your computer or other USB device. The micro-USB connector is smaller and thinner than the previous USB Mini-b standard while offering better performance. Its small form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a transfer speed up to 480 Mbps. This cable is compliant with USB 2.0 specifications.
  • Efficient connectivity
    The C2G USB 2.0 A to Micro B Cable ensures a reliable connection between devices, featuring a 4-pin USB Type-A connector on one end and a 5-pin Micro-USB Type-B connector on the other. This design facilitates seamless data transfer and charging capabilities for a wide range of electronic devices.
  • High compatibility
    Compliant with USB and USB 2.0 standards, this cable is designed to work with a multitude of devices. Whether connecting to a smartphone, tablet, or other USB-enabled device, users can expect consistent performance and data integrity.
C2G USB 2.0 A to Micro B Cable - USB cable - USB to Micro-USB Type B - 4 m
USB cable
Length
4 m
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
USB / USB 2.0
USB cable
Length
4 m
Connector
USB / USB 2.0
Length: 4m
Brand: C2G
