Replace your overused or misplaced power cable, or just get some extra cords for convenience. This non-polarized power cord is designed to work with laptops, gaming consoles and other audio/video equipment that uses a 2-slot non-polarized power cord. Plus this heavy duty 18 AWG cord features a fully melded design for maximum durability and long life. The female connector, often called a figure of 8, plugs directly into the device while the male connector plugs into a standard power outlet.
Versatile compatibility
Designed specifically for PCs, this power cord seamlessly integrates with a wide range of computer systems, ensuring a reliable power connection every time. -
Robust construction
Featuring an 18 AWG thickness, this power cable is built to deliver efficient power transmission while withstanding the rigors of daily use. -
Secure connections
Equipped with a power IEC 60320 C7 connector on one end and a power CEE 7/7 male connector on the other, it ensures a secure and stable connection to your power source and device.
- C2G Non-Polarised Power Cord - power cable - power IEC 60320 C7 to power CEE 7/7 - 3 m
- Power cable
- Molded
- Length
- 3 m
- Localisation
- Europe
- Connector
- Power IEC 60320 C7
- Connector (Second End)
- Power CEE 7/7 - male
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 18
- Rated Voltage
- AC 250 V
- Molded
- Length
- 3 m
- Black
- Localisation
- Europe
- Connector
