C2G 3m DisplayPort Male to Single Link DVI-D Male Adapter Cable
Quicklinx: 9MRSWS00 Mfr#: 84330
Length: 3m
Select:
£28.63 ex VAT
£34.35 inc VAT
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Colour
  • Resolution
    Up to a 1920x1200 video resolution is supported
C2G 3m DisplayPort to Single Link DVI-D Adapter Cable M/M - DP to DVI - Black - DisplayPort cable - 3 m
DisplayPort cable - single link
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
DisplayPort cable
TMDS Links
Single link
Length
3 m
Connector
20 pin DisplayPort - male
18+1 pin digital DVI (Single-Link) - male
Length: 3m
Brand: C2G
