This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
- C2G 2m DisplayPort to Single Link DVI-D Adapter Cable M/M - DP to DVI - Black - DisplayPort cable - 2 m
- DisplayPort cable
- Technology
- Shielded
- Length
- 2 m
- Connector
- DisplayPort - male
- Connector (Second End)
- DVI-D - male
- Black
- Limited lifetime warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- PVC
- American Wire Gauge (AWG)
- 30
- Length
- 2 m
- Black
- Connector
- 20 pin DisplayPort - male
- 18+1 pin digital DVI (Single-Link) - male
