C2G 3m Cat6a Shielded Patch - Blue
Quicklinx: 8H11WS00 Mfr#: 89911
Length: 3m
Colour: Blue
£11.20 ex VAT
£13.44 inc VAT
This Booted Shielded Cat6a patch cable is ideal for use with 10GBase-T ports and equipment, such as network adapters, hubs, switches, routers, DSL/cable modems and patch panels, and will protect a high speed 10 Gigabit network connection from noise and electromagnetic interference. For voice/data/video distribution, this cable will handle bandwidth-intensive applications and drastically reduces both impedance and structural return loss (SRL). Each patch cable is fully tested to meet ANSI/TIA 568 C.2 Cat6a component requirements. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded a network installation. Each cable is individually labelled with the length for ease of use.
  • Warranty Details
    This product carries a lifetime warranty
  • Cable Type
    Stranded SSTP
  • Conductor Type
    26AWG (7/0.16) (bare copper)
  • Wiring Scheme
    568B
  • Jacket
    PVC
C2G Cat6a Booted Shielded (STP) Network Patch Cable - patch cable - 3 m - blue
Patch cable - CAT 6a
Shielded twisted pair (STP)
Wires per Cable
8 wires
Molded, snagless, stranded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Length
3 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 600 MHz
Length: 3m
Colour: Blue
Brand: C2G
