C2G 3m Cat6 550 MHz Snagless Patch Cable - Orange
Quicklinx: 6BSXWS00 Mfr#: 83577
Length: 3m
Colour: Orange
£3.81 ex VAT
£4.57 inc VAT
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures high-speed data transfer for server applications, cloud computing, and HD video streaming.
  • Durable design
    Constructed with a PVC jacket and 24 AWG copper, this patch cable is built for durability and long-term use. The gold-plated RJ-45 connectors provide a secure and corrosion-resistant connection, enhancing signal quality.
  • Universal compatibility
    Featuring a T568B wiring scheme and compatible with PC systems, this network patch cable offers a versatile solution for a wide range of network requirements. Its universal design ensures it can be easily integrated into existing network setups.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - orange
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Orange
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
3 m
Orange
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 3m
Colour: Orange
Brand: C2G
