C2G 3m Cat6 550 MHz Snagless Patch Cable - Green
Quicklinx: 6BQLWS00 Mfr#: 83429
Length: 3m
Colour: Green
£3.90 ex VAT
£4.68 inc VAT
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures optimal performance for your networking needs, whether at home or in the office.
  • Durable design
    Constructed with a PVC jacket and 24 AWG wire, this patch cable is built for durability and long-term use. The gold-plated connectors not only provide a reliable connection but also resist corrosion, ensuring a consistent and quality connection over time.
  • Universal compatibility
    Featuring a T568B wiring scheme and RJ-45 connectors, this cable is compatible with a wide range of devices and networks. It's designed to meet the requirements of PC environments, making it a versatile choice for various networking setups.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - green
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
3 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 3m
Colour: Green
Brand: C2G
