C2G 3m Cat6 550 MHz Snagless Patch Cable - Blue
Quicklinx: 6BPWWS00 Mfr#: 83389
Length: 3m
Colour: Blue
£5.67 ex VAT
£6.80 inc VAT
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-speed connectivity
    Experience seamless Internet and network connectivity with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support frequencies up to 550 MHz. This cable ensures your data transfers and online activities are efficient and uninterrupted.
  • Durable design
    Constructed with a PVC jacket and featuring gold-plated connectors, this patch cable is built for longevity. The durable design resists corrosion, enhances electrical conductivity, and ensures a reliable connection between your devices.
  • Universal compatibility
    With male RJ-45 connectors on both ends, this cable offers broad compatibility with a variety of devices. Whether connecting to PCs or integrating into a complex network setup, its universal design ensures easy integration.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 3 m - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Molded, snagless, stranded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
3 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 3m
Colour: Blue
Brand: C2G
